Hello, I am new in this I have a problem with an Opel Corsa C type Z12xe and changed the cooking joint and the chain kit with Us useful useful ones but now it does not start for me that does not arrive gasoline does not fill the injection ramp
Hi Jesus, what may have happened that the taques have been frightened with oil and have valves stepped off because of this that does not start (usually happens in the hydraulic taque) I do not know if you will have fixed before mounting the cylinder head in this detail. Some go around hand until they are closed (it takes a while until they are emptied). Another thing is that gasoline does not reach the ramp or that does not take pressure, make sure you contact and remove the gas sleeve if you work the pump when you turn the engine.
The first thing is Checar that you are missing for starting if it is a spark, or fuel, nothing from the other world, now remember to connect the lands that go from the thermostat that one always forgets one and the cars do not leave hahaha
