I have a rings problem in a Daewoo Ladies 93 engine, I have not yet disarmed because I have a world to find the technical specifications of tightening of the screws. This car uses a F8CB, Suzuki engine. It is used by the Daewoo
Matiz, but unfortunately the file that is found on this website on the nuance does not include those data that I require. Someone told me that the Chevrolet Spark also uses it.
Please help with such data, I need tightening values and sequence of butt screws, connecting rod covers, at once the crankshaft bench cover, even better if they facilitate the technical file with all those specifications. Thank you so much.
