- Thanks received: 1
06-19-2025 Hits: 699 Technology
Excuse me if it is a Fiat may that the flasher valla in the command of lights and for that you must take the cover that covers itHe wrote: Hi is not reliable what you are looking for is flasher of intermittent and is located in the fuse box if you do not know how it is to do the intermittent OH the hazard and the box that sounds is and if it does not work only give it a blow and will begin to flash in general because of the work it has the welding takes off but it is better to change it luck I hope to have helped in something ...
