Suzuki Alto does not start ...
11 years 1 month before #46258 by manual-mecanica
Suzuki Alto does not start ... published by Manual-Mecanica
Hello Friends of the Forum, I need to know if someone happened to someone: I have stood problems with a 4 -cylinder tall suzuki, the injectors do not open in the first game, everything is revised even the computer, injectors, wiring, benzine pump, but as data I give it game with clean carburetor and immediately part of a moment I thought it was the temperature sensor and in that I am I am attentive to your comments. : P
11 years 1 month before #46275 by manual-mecanica
Manual-Mecanica response Suzuki Alto theme
Mmmmm checked the pulses of the injectors, and the injectors in a test bench in case the flies, so you comment everything goes through fuel feed, you want the pump not lift the correct pressure.
11 years 4 weeks before #46420 by manual-mecanica
Check the injection system
11 years 4 weeks before #46423 by manual-mecanica
You have reviewed the pressure of the pump in the game, layers have little pressure and therefore a bad injection at the beginning
