Electricxa failure in the Zetec 1.8L 16V escort
11 years 1 month before #46380 by manual-mecanica
Manual-Mecanica response on the topic Falla Electricxa in the Zetec 1.8L 16V Escort
or the CKP (crankshaft collector) that has: EVIL: and is making intermittent failures
11 years 1 month before #46393 by manual-mecanica
But it does not start due to lack of spark or lack of fuel, proof and letharms
11 years 1 month before #46395 by manual-mecanica
11 years 4 weeks before #46410 by manual-mecanica
I lean on a topic in fuel feeding. It could be from the simplest as saturated fuel filter, to the fuel pump for dying. Several things can happen within this option. First of the pump itself is generating less pressure from the necessary and on the other hand it could be that the pressure regulatory valve is not sealing well and it does not have enough pressure. I lean on bomb in poor condition or regulatory valve. To get doubts, get a manometro and measure the pressure on the injection ramp. Ovbarily, there may be countless problems that generate similar situations. What should you be more detailed when explaining the fault: the engine once starts perfect? Regulates well and even, you already go around, when accelerating reacts well? Sometimes it is accelerated? What I advise is to look for the problem and do not play to change pieces until you find the failure. Greetings and luck
