HEATING PROBLEM PARTNER
11 years 1 month before #46400 by manual-mecanica
Partner heating problem published by Manual-Mecanica
Hello everyone I have a problem with the heating of my peugeot partnes 2000 1.8 does not heat pull only cold air I had told me that I take out the hoses of the heating and send them water so that it uncovered it.
11 years 1 month before #46402 by manual-mecanica
Manual-Mecanica Response on the subject HEATING PARTNER
Like the cold/heat position control, it does not work and does not open the way to the circulation of water through the small heating radiator, with heat engine and the "heat" position, touches the input hoses and exit of heating to see if the two are hot, if not so you will have to check the control from inside the habitaculus. greetings!!
11 years 1 month before #46403 by manual-mecanica
Very good what Iamael says but let's not forget the resistance of Seramica that nobody fish it and is always alone and it is the last one who looks hahahaha
