Airbag light
11 years 4 weeks before #46425 by manual-mecanica
Airbag Light published by Manual-Mecanica
You had to disconnect the airbag to get the steering wheel to a goal 1.6 year 2010 to change the key of lights. When assembling everything was the light of the airbag on. Is there any way to reset without a scanner?
11 years 4 weeks before #46426 by manual-mecanica
Manual-Mecanica Response on the Light of the Airbag
No, it is left without a scanner, they left the airbac connect? You can try the following, disconnect the negative terminal about 30 seconds and then you open contact about 15 seconds, you saw it about 10 seconds, you have this prosecutor 3 to 4 times and give start, in some echus this serves as reset luck.
