Fiat 147
16 years 11 months before #4106 by manual-mecanica
Fiat 147 published by Manual-Mecanica
Hello, very good for everyone, first of all, I want to tell you that I am new in this and the truth is that I need to solve a problem that I have with my car.
When I make it work without any problem but after a while walking it begins to lose speed as if I lost precion and reduces the speed even if I have it by 4th and I have to reduce changes until I stop
complete
16 years 11 months before #4108 by manual-mecanica
Manual-Mecanica Response on the Re: FIAT 147
hi, friend. I hope to help you with your problem that it seems to me that it is a refinement problem. For the year I should possess platinum and condenser which would be good to change them, as well as the
Bijias air and fuel filter. It also controls empty membrane functioning. After these verifications he responds
13 years 11 months before #23803 by manual-mecanica
Emmm but the problem only occurs when acquiring speed? Because it usually happens that the car its acceleration raises well but the marches are slow is a problem of the clutch disk : Laugh:
13 years 11 months before #23809 by manual-mecanica
Czech the spark plugs and compression maybe it is wetting them
