Seat Cordoba 1.6i
10 years 11 months before #46903 by manual-mecanica
SEAT CORDOBA 1.6I published by Manual-Mecanica
: Dry: hello.
I have a Seat Cordoba 1.6 Gasoline injection, sometimes I stop, whether walking or slowing down. Then you give him and start perfectly, and until he does again. Does anyone know what can be? I went to remove the gasoline pipe that reaches the ramp and had gasoline and pressure. Let's see if anyone knows anything.
Greetings
10 years 10 months before #46905 by manual-mecanica
Manual-Mecanica Response on the Seat Cordoba 1.6i
Hello, you say that gasoline seems to go well, but you do not say if the spark fails, or by the module-bobbin on or by the distributor hall (if it is damaged, it would not be a signal and would not come back to start), look to see if when you stop does not throw spark or do it sometimes; If you have been pulling you that the coil usually fails (it goes along with the module). Greetings!!
