- Thanks received: 1
06-19-2025 Hits: 741 Technology
Thanks Maurog for answering me, but it's just a written problem, it's not for any car.Maurog wrote: The data you need would have to mount the vehicle in a Dyno there they connect it with several sensors and get all the data to the braking of the same I do not know what country you are but not everyone has said device greetings
Hello Lord Strange, the first thanks for the answer. You will see myself realized that the problem was wrong. They ask me for angular speed of the wheels.Lord Strange wrote: Hello, I have not done a problem of these years, but I think you just have to make rules of three, but the result will give you in rpm. If you want in km/h you need to know the tire diameter.
1500rpm: 1.4 = 1071.42Rpm output in change.
1071.42RPM x 25: 40 = 669.64RPM output in the differential.
669.64rpm: 3 = 223.21rpm on the wheel.
To know in km/h, if for example you mount a 195/60 R15 wheel, you must first know the total diameter of the tire, then the distance it travels in
1
return and
final 117mm .
1000000
0.00193km
