Seat Cordoba 1.4 MPI does not start
10 years 9 months before #47358 by manual-mecanica
Seat Cordoba 1.4 MPI does not start published by Manual-Mecanica
My wife's cordoba does not start. He is about thirteen years old is the famous one in the Sarpicadero. I do you to contact and light all the normal lights. When starting it does nothing at all and the lights are not going down. I look at the battery voltage and it's correct. I check the relays and are perfect. It will not be that the automatic of the starter engine has gone (start -up)
10 years 9 months before #47359 by manual-mecanica
Manual-Mecanica response on Seat Cordoba 1.4 MPI does not start
The 1.4 MPI what usually fails is very much is the ignition module-bobbin, but not also forget that so that it works and throws "spark" also carries a "hall" in the one of theco and it is also damaged, (this is when the engine turns and does not start ...) I do not know if I understood well if the starter turns to turn when turning the key, if not, try to give the engine to start a hip. If it was bad "brushes" and that is why it does not turn, it rules out that it is the key encoded. Another possibility would be to look that it is not a problem of the key of the key itself (spent contacts), greetings !!
10 years 9 months before #47414 by manual-mecanica
If the engine does not turn to you at the time of the start, first Czech that the sheet sends the starter of the starter engine and if it does and nothing happens to the start of themselves, the plates also fail a lot.
