Help in Vectra B 2.0 dt 100 hp
10 years 9 months before #47388 by manual-mecanica
Help in Vectra B 2.0 dt 100 hp published by Manual-Mecanica
:( Someone can give me a cable, I am out of Spain curing my Opel Vectra B 2.0 dt 100 hp, good at first the fault light has been turned on and the RPM No VAT account, already lost a lot of force. It seemed an atmospheric die with 20 hp.
The fact is that after cooling I have started it and marches perfectly but when it reaches the normal gear temperature it happens again. I have been investigating several forums and the safest thing is the crankshaft revolution sensor.
Someone can give me a hand and tell me where the happy sensor is located and take the steps to Sur for replacement. I would thank you very much since as I have commented I am in France and the workshops are expensive and also the problems is how to explain it to the mechanic since I am not very good with the language.
10 years 9 months before - 10 years 9 months before #47390 by manual-mecanica
Manual-Mecanica response on the subject Help in Vectra B 2.0 dt 100 hp failure
Hello, your Opel's collector is located in the lower front of the engine, approximately following the photo arrow
, it is accessed under the car, it is black plastic with a small twist, it is a typical failure of these engines and is easy to change (with a little patience and desire to stain your hands) ;) , there goes a photo to see how it is more or less
, I hope it helps you, good luck.
Latest edition: 10 years 9 months before by .
