Luv Dmax Diesel Motor doesn't turn on ...
10 years 8 months before #47587 by manual-mecanica
Manual-Mecanica Response on the Luv Dmax Diesel Motor does not turn on ....
Brother If you do not have Scaner These fried look at this image of a DLC for Ke Mires where Pin 6 and the Pin4y5 are mass (Earth; Negative) you can connect it to any, the two are mass for ker of the error codes and when you have them you have them to give you to mean. Greetings from Honduras www.google.hn/search?q=connector+obd&new...rotocols%3b300%3b194
10 years 8 months before #47589 by manual-mecanica
It seems to me that if it does not start, it will have to do if Gasoleo gets to the pump, if you will not have an air intake in the aspiration that has made the diesel be returned leaving air to be stopped ... it would have to be turned and loosen an injector to see if diesel comes out, if not; You will have to purge the injectors in this way, if Gasoil does not enter the pump, look at the "stop" electrovalve if it reaches the current or stayed or the coil of it is cut. The white smoke may be that it takes air in the aspiration line (from the deposit to pump) and that the injectors' pipes have air, or that the distribution is outdated (draft). As for the DTC bridging in an OBD 2 I am not aware that it can be done, in the ALDL if it is how the codes are removed per flash, but in obd 2 to pull scanner .. greetings !!
10 years 8 months before #47629 by manual-mecanica
If you can, greetings
