Nissan Sentra 1996 with failures when starting
10 years 8 months before #47684 by manual-mecanica
Greetings to all mechanics manuals. I have a dilemma with the starting system of my Nissan Sentra 1996 with GA16De engine and automatic transmission. For 6 months I was looking for the solution but it was difficult for me. The car's board does not turn on any indicative light (eye: none) and at the time of ignition (start), nothing happens. I replaced all the fuses, relays and battery. Nothing. The lights, the horn and the cabin light light, but still nothing. I think of three things: 1. The computer 2. The fuse box 3. Any unknown electrical damage.
I attach a photo of this piece to know your real name.
I hope you help me with my case. I am about to take it to the scrap cruster.
10 years 8 months before #47715 by manual-mecanica
Manual-Mecanica response on the Nissan Sentra 1996 topic with failures when starting
Hello, the rifle that shows is not electronic The car model does not carry Bsi the travler can be a lack of food by fuse or by calbe that can also be lack of mass can also be affected the same board of the ignition you would have to pass me more data and if you took the food of the same since it may not be feeding to me a photo of the engine to know more greetings
10 years 7 months before #47814 by manual-mecanica
You checked the ignition module of the contact sheet.
9 years 5 months before #50593 by manual-mecanica
Good morning, your board may be burned or disconnected the electric part are not always fuses. Relay etc. You occupy the board and check that it is reaching food
