Intermittent problems
10 years 7 months before - 10 years 7 months before #48052 by manual-mecanica
Manual-Mecanica Response on the subject Intermittent problems
Hhola, hahaha, sweat the fat drop, I am with a chub in a sling, and another one already came, which a priori is not easy, I am not electronic, I am a technician and mechanical engineer, out of necessity I have had to self -considerate in the issues of electronics basically because almost all the new cars are like this citroen ... personally I venture up to relay and signs of activation, I have electronic "pure" chips, memoirs, programming, etc.
Returning to Citroen, about the need to amplify the signal that you take from the telecoming, yes, your appreciation is correct, it is most likely ...
now in the BSI, for me the most likely, it is that you reach 2 relays because, depending on the type of Bsi and origin, use 1 reliable for the signaling and the other for the hazard or arrest lights ... It would be plans, examine the behavior of the circuit of the side lights that if they work, and if the second relay is for hazard, then having clear the operation within the BSI of the OK circuit, the bad tested ... I do not know if you understand me, there are times that I complicate myself in excess ... when explaining something simple .... hahaha. Finally if you turn on the hazard, both sides work? When do you give to the bad side, the module of the Istrums board should issue signaling sound signal? This happens like this or not? I test live circuits inside computers, such as this BSI, disarming them, isolating them with a cloth (care with the short) and I measure what I want to verify, obviously with the connectors put, only with the BSI "piluchita" hahaha, like almost all ... "they" look better devoid of their clothes ... hahaha. Greetings friend, I am on the lookout.
Last edition: 10 years 7 months before by . Reason: Spelling
10 years 7 months before #48053 by manual-mecanica
Thanks companion, today I am determined to have an approach to what I am going to do as long as I do not take the mare I will place the com 2000 that I have before ......, better to prevent, well less talk and hands to work, to burn Bsi and Com 2000 no more ......., it's a joke, thanks again.
10 years 7 months before #48061 by manual-mecanica
Hello everyone, haha, thanks for rectifying my mistake, in the previous post. Rodrigo You are right the luminous signal is sent by the instrument module and the sound signal the commutation interface module under the board, it is exactly how that system works, but it is the BSI in bidirectional communication with both modules who switches in the last case is type of circuit, interesting not:) .... Kind regards.
10 years 6 months before #48076 by manual-mecanica
I cannot catch this pulse, I am giving up, I just need to make a circuit outside the intermittent BSI for a Citroen Berlingo 2011, hahahaha, I think that the clutch is skating me with this, I do not know what to do also that the space I have is very small to try some food, from the com 2000 there must be a pulse that goes from this one to the Bsi, I do not know how to look for it, I know how to look for it.
