Toyota yaris rpm very low
10 years 7 months before #48364 by manual-mecanica
Toyota Yaris RPM very low published by Manual-Mecanica
Hello friends of this forum I have very low RPM problems about 460 ... 500 with hot engine I have already cleaned the shutter but follow the same problem I do not know if they can help me as it is done to put the normal rpm .... have if you can program with a Scaner ....... I will thank you enough
10 years 7 months before #48374 by manual-mecanica
Manual-Mecanica response on the topic Toyota Yaris RPM very low
Hello, you have reviewed the state of the battery ...
10 years 7 months before #48375 by manual-mecanica
If the battery is in perfect condition ... in cold motor the problem is the problem starts hot engine at 30 km
