VERNA 2004
10 years 5 months before #48490 by manual-mecanica
VERNA 2004 Published by Manual-Mecanica
b. Diias friends doing presence and discomfort at the same time greetings to all the colleagues in the field I asked me if someone has the Verna workshop manual I have had problems with the gasoline pump the markadFor of the board did not Marka but sako the bomb and try it outside
10 years 5 months before #48497 by manual-mecanica
Manual-Mecanica Response on the topic Verna 2004
You do not need Manual Check that the 5 vols of the fuel level marking arrive in the pump file if they arrive this voltage, it is little that this is the problem on the scoreboard or in the cable that goes to the board or the same board to know better bridge the food cables of the marker not of the pump since there are 12 vy mass could cause a short circuit greetings
