Inexplicable consumption
10 years 1 month before #49177 by manual-mecanica
Inexplicable consumption published by Manual-Mecanica
Hello,
I'm fighting 6 months ago with the consumption of refrigerating liquid from my Diesel spazio.
I do about 10 km and the level of the liquid lowers me a lot in the container
since then I changed all the snack hoses, the thermostat and the heating tap.
It is not observed with the naked eye lost in the engine radiator or in the heating,
it is also not seen that there is water in the engine oil
when complete refrigerant liquid I always do it to the mark that is in the middle of the container and when I take the cover from it with the hot engine a "shhhh" is heard as if there was pressure inside the container (I do not know if this is correct).
The liquid circulates well inside it
if I leave the car stopped 2 or 3 days the liquid does not fall so that the problem appears when
the temperature is never passed the 90 degrees and the fan is well
at first glance there is no loss noly loss anywhere or even with the hot engine
no longer know what to do. If someone can throw me a clue to solve this I appreciate it
greetings
Marquin
10 years 1 month before #49179 by manual-mecanica
Manual-Mecanica Response on the topic Inexplicable consumption
Control the temperature sensor that is working well, check if the canister valve is not locked open and take fuel pressure to see if the regulator is fine. :)
10 years 1 month before #49180 by manual-mecanica
Sorry, that answer was for another forero, in your case it can be a damaged butt joint, the refrigerant passes to the cylinders and consumes it in the form of steam for the exhaust, controls that, greetings.
10 years 9 hours before #49526 by manual-mecanica
It has a blow joint
