Monza does not work the benzine pump
10 years 1 month before #49327 by manual-mecanica
Monza does not work the benzina pump published by Manual-Mecanica
Well guys, I comment: The other day I use my vehicle a Chevrolet Monza from the year 96 at the time nothing happened but on the way I felt how the car did not throw accordingly. After that back home without stopping the car anywhere I get home and set the car.
summarizing when I arrived at my house I stopped the vehicle and then when I went to use it hours later the car I give contact the pump but did not turn on, cut contact and repeat again after that the benzine pump did not work again there so the vehicle does not start, after that verifies the current that arrives at the pump and does not arrive current.
Can anyone help me ???
any possibility that can be?
PS: Change the ignition module but continue with the same problem
