Megane Calentón 2 1.9 DCI
10 years 1 month before #49331 by manual-mecanica
CALENTINE MEGAN 2 1.9 DCI Published by Manual-Mecanica
Good to all ... yesterday the temperature needle rose and the stop test was lit. ..... After verifying that I had nothing (apparent) for the engine, I left it a few hours to cool, start it and not know ... In standing up not ........ what the pussy happens to you ??????
10 years 1 month before #49332 by manual-mecanica
Manual-Mecanica Response on the topic Megane 2 1.9 dci
Hello good. So a boat soon, after having proven that there are no liquid leaks, that when you remove the plug with the car started in the water do not appear bubbles as if they were injecting oxygen into a fishbowl and that there are no oil residues in contact with the water, which would make it would be to change the thermostat. Luck.
