VW Amarok does not start
10 years 4 weeks before - 10 years 4 weeks before #49346 by manual-mecanica
VW Amarok does not start published by Manual-Mecanica
I have a VW Amarok that has no injection pulse, or feeding in the preheater is Diesel Cammon Rail, I have a P0651 Code Reference Sensor High Voltage Reference Sensor
Latest edition: 10 years 4 weeks before for .
10 years 4 weeks before - 10 years 4 weeks before #49347 by manual-mecanica
Manual-Mecanica response VW Amarok theme
I hope this data serves you. Fuente Translate.google.com.ar/translate?hl=en&...ult.aspx&prev=search
Greetings
What does this mean?
OBD P0651refers Code to
these 5 volt reference circuits are independent of each other outside the PCM, but they are searched together inside the engine control module (ECM). Therefore a circuit condition in a reference circuit of 5 volts of the sensor can affect the other reference circuits of 5 volts of the sensor. The ECM controls the tension in the 5 volt reference circuit.
Causes
The possible causes of Code OBD P0651
- Sensor Short - Sensor Circuit in Short - ECM FAILED The error code is generally active in the detection of the following conditions: the ECM has detected an out of the voltage range in the reference circuit of 5 volts 2
10 years 4 weeks before #49348 by manual-mecanica
If that knew, the issue is that can cause me not to have injection and feeding pulse in the preheater?
10 years 3 weeks before #49357 by manual-mecanica
When this voltage variation the injection is inhibited as protection.
It can be for a burned transistor in the module.
As far as I know, it was a very common problem in the first ones that came out.
