Fiat Uno Speed ​​Failure
10 years 3 weeks before #49363 by manual-mecanica
Manual-Mecanica response on the subject Fiat Uno Unit
The counterweights are to delay the top of the 2,000 rpm, they cannot make that fault
10 years 3 weeks before #49365 by manual-mecanica
Some mechanics have given me the opinion that can be the ignition module that is bad and the signs of the captain coil is really processing I really do not know what to do with this fault
10 years 4 days before #49504 by manual-mecanica
Hello, you have to regulate the valves and give them the fair light that the admission and escape
9 years 11 months before #49658 by manual-mecanica
Hello, you checked the advance, it is likely that this a little late or you can have the advance of the (distribution) tightened osi is empty sleeve.
9 years 11 months before #49659 by manual-mecanica
As they tell you, the coach can be behind, try to advance it, it would have to think about how the engine and the valve game that have also spoken previously. The carburetor adjustment (including the level of the Cuba) and that does not have air intakes or in the butterfly axis or in Latapa or at the base of this plenty that says it is important. If that of the Coin (or distributor) carries progress lungs (in addition to counterweights), it would not be to look that is not drilled and also not to advance, take a breath. Well, they can be several things or the sum of these that do not go as before (even spark plugs that are not of the degree influence), if it gives clues of whether it smells a lot of gasoline, black or white spark plugs in electrode (eg) it will be easier to tell you among all. Greetings!!
