P2096 fault code
10 years 3 weeks before #49378 by manual-mecanica
P2096 fault code published by Manual-Mecanica
Hello friends of this I have a problem with Kia Rio of 2013 with 15,000 km of travel always appears this P2096 fault code ... that is catalyzer my question is how I can solve this failure that appears ....... always uses gasoline 90 and the rest of the engine is fine only appears always appears always this failure help please.
10 years 3 weeks before #49387 by manual-mecanica
Manual-Mecanica response on the topic P2096 Failure Code
Hello, I recommend doing these reviews, low fuel pressure caused by obstructed filter, low fuel pump, stubborn or damaged fuel pressure regulator, obstructed or leaks injectors, luck
10 years 3 weeks before #49404 by manual-mecanica
Thanks for the fact,
the injectors I did the test with ultrazonid and is very well correct the only one can be as you explain the fuel pressure regulator I imagine it carries inside the tank, in the entry of a rail of injectors there is no return of fuel, there is only a pipe pipe to the rail.
10 years 3 weeks before #49407 by manual-mecanica
Measure the fuel and flow rate ... Keep in mind escape tube leak ...
10 years 2 weeks before #49448 by manual-mecanica
Normal as a flow and pressure should carry ....... Thank you for your help an estimated hug
