I have a fault code P 0622 in my Dodge Neon
10 years 3 weeks before #49400 by manual-mecanica
I have a fault code P 0622 in my neon dodge published by Manual-Mecanica
10 years 3 weeks before #49402 by manual-mecanica
Manual-Mecanica Answer on the subject I have a fault code P 0622 in my Dodge Neon
How friend I saw your comment of the code having if this can help you in this code the possible causes are:
- The load of the low
- defective battery the current generator (alternator)
- The harness is short or open
10 years 3 weeks before #49403 by manual-mecanica
controls that the alternator is not loading more, it must be between 13.8 and 14.2 volt
9 years 11 months before #49680 by manual-mecanica
This code has to do with everything is involved in the cargo system of the car, it has to start with the basic battery and alternator, if this is fine, check the current signal that goes from ECU, wiring harnesses, and cable resistance.
