LIGHT LIGHT POSITION Avensis 2.0D, 2002
9 years 11 months before #49610 by manual-mecanica
Light Fall Position Avensis 2.0D, 2002 Published by Manual-Mecanica
Hello, I have a Toyota Avensis of 2002, 2.0d, to which I was going to change the position light bulbs of the rear pilots, but once changed they still did not work. I started looking for the fuse if that were the problem, but I can't locate it. Look in the box on the engine to the right where the relays are and I don't see any molten. Any idea? or should I look in another area the fuses? Thank you very much greetings
