- Thanks received: 1
06-19-2025 Hits: 502 Technology
ATRM wrote: P0733 Generic Gear 3 Incorrect ratio
P0734 Generic Gear 4 Incorrect ratio
When brand failures in gear relationship at a certain speed, it is usually mechanical failure. Did you check the double drum? In this drum applies forward /direct that the applications influences 3rd and 4th. Check this drum very in detail because they crack and it is very difficult to detect the fissure. Also inspect the status of the pistons working in this double drum.
Luck !!
The king wrote: You are in everything I correct my dear companion check the pastes of that double drum but never check the piston I went the roll and tomorrow I will take it out since it is not necessary It is heard that it escapes air through the league ....... I leave all this and post the results ... thanks
