The start -up does not comply with the steering wheel
9 years 8 months before #50257 by manual-mecanica
The engine was overheated and ended by riding a new shirt, kigañal and connecting shells we arm everything and fed it to the box, I connect cooling, fuel, wiring, amounting to start and test, the start turns but does not fit, ???? I check the manuals I ask and nothing reviews the order of the pieces in the diagram of the motor manual J20 to nothing mystery is as if the start was not of this engine the Bendix shoots but the teeth do not reach the zipper, help
9 years 8 months before #50267 by manual-mecanica
Manual-Mecanica response on the subject The start-up does not coup
Hello retacito, the truth is that the only thing that occurs to me is that you check what fork that drives the vendix is ​​well armed, and see that the vendix would have to try having it outside with a wood that locks and not zafe, if not what is left is that the crown is spent, another thing does not occur to me. Greetings Alejandro
