Red witness oil pressure R1200gs
9 years 8 months before #50261 by manual-mecanica
Red witness Oil pressure R1200gs posted by manual-mecanica
I'm breaking my head.
I have an R1200GS year 2012.
Three months ago maintenance was made. CASTROL POWER RS RACING 4, 5W40 OIL MORE ORIGINAL FILTER IS CHANGED.
The ox eye has an oil almost to the maximum. But at 6 temperature stripes the witness (red) of oil pressure is turned on.
When the motorcycle is in idle, the red pressure witness is turned on and so that it goes out, I must keep it accelerated,
change the oil pressure sensor, but follow the problems.
I just changed oil now and filter, I put a semi -synthetic castrol 20W50 plus original filter and follow the problem.
I don't think something is doing mass, since I have not touched the motorcycle at all, except in oil and filter changes.
If there was something doing mass the red witness would turn on only when giving contact and it would be permanent, but it only happens when it reaches 6 stripes of the temperature.
I made a motorcycle scanner and no error code appeared
9 years 7 months before #50273 by manual-mecanica
Manual-Mecanica response on the red witness theme R1200gs
Look sometimes the replacement filters do not carry or do not bring a valbule, set if you have the old man who took him for the first time greetings
9 years 7 months before #50281 by manual-mecanica
Capon777 wrote: Look sometimes the replacement filters do not carry or do not bring a valbula, if you have the old man who took him for the first time greetings
I don't have the old filter, but I put an original BMW
