Neon problem 2003
9 years 5 months before #50587 by manual-mecanica
Problem in neon 2003 posted by Manual-Mecanica
Hello good evening. Someone to help me, I have a 2003 2.0 engine. I do not get the signal to the 2 and 3. The engine I turn on and work well for 4 seconds and then cut the signal asia the mentioned incentors. The computer wiring is already checked and everything indicates that it is fine. What could be the fault? X please appreciate them a lot. Thank you
9 years 5 months before #50591 by manual-mecanica
Manual-Mecanica Response on the problem in neon 2003
Hello how are you ? Unfortunately, the fault occurs to me that it can come through the ECM, you should try to get another and try it since perhaps you must have some erroneous configuration parameter. As long as I Descartes Electric Theme and that does not present intermittency in its feeding of the injectors. Greetings.
9 years 4 months before #50598 by manual-mecanica
Thank you. I'm going to deal with what you say. I thank you
9 years 4 months before #50601 by manual-mecanica
Perfect, when you have new novelties, share what you have done if you can, I hope everything goes well! Greetings from ARG.-
