Chrysler Neon
9 years 4 months before #50783 by manual-mecanica
Chrysler Neon published by Manual-Mecanica
The 1996 Neon is broken by the crankshaft rotation sensor, changed several times and continues to break it, does anyone know anything? What can I check?
Thank you!
9 years 3 months before #50786 by manual-mecanica
Manual-Mecanica Answer on the Chrysler Neon
literally breaks it?
9 years 3 months before - 9 years 3 months before #50788 by manual-mecanica
It is definitely broken by playing against the shock (toothed wheel) that is mounted with cranks to the cranks, you will have to remove the motor càrter and observe if it is loose or crooked, for this you will have to take out the spark plugs to facilitate the rotation by hand until you see where it plays against the sensor placed in its place, you do not need to put a new one, to use a new one. hits.
I put a photo to see where the shock is.
Last edition: 9 years 3 months before by .
9 years 3 months before #50789 by manual-mecanica
Apparently it is electric, the connector had broken and sure that the cables have been placed in short.
It does not seem beaten.
Thank you
9 years 3 months before #50790 by manual-mecanica
Where is it from
