Forg Focus transmission oil review
9 years 3 months before #50887 by manual-mecanica
Greetings to all ,,, my query is about how I check the level of automatic transmission oil in a 2013 Ford Focus because it has jaloneos sometimes but only occurs in low revolutions .... I would appreciate how to let know how to measure the level if that is what can be bothering me ... Thank you
9 years 3 months before #50889 by manual-mecanica
Manual-Mecanica Response on the topic Transcion oil review forg focus
Hello Mecmoch, the 6 -speed automatic boxes of the Ford Focus from 2012 onwards with the 2.0 direct injection gasoline are robotized mechanical transmissions. I have already seen 2 DSP6 with premature problems. The oil level is measured as in a manual gear. It has a filling and emptying cap. Ford and Gerag (the box manufacturer) say that the oil (special) is for life ...
that box is a true robot, especially the TCM (transmission module) attached to the box. Being a mechanical box (no torque comverter, no oil pump, all the control is electronic. I suppose to make a scanner, revi, sar the memory memory of the TCM and PCM.
For the symptom, the DSP6 Ford-Gettrag, there should be oil leakage from the box to the clutches (2, are dry) or is starting to fail the
TCM breakdown, you must perform the learning procedure of the clutches and electric motors that move the drums (drums) inside the box through a cascade of pine nuts. PCM
. The TCM, then you must do all the position learning procedures of the DSP6, the same the TCM for another one. In the future.
9 years 3 months before #50893 by manual-mecanica
Thanks a thousand for the explanation ... greetings from Panama
