Aid
9 years 1 month before #51051 by manual-mecanica
Help published by Manual-Mecanica
Greetings; I have a Volvo S60 2.4 5Cy of 2002, the computer was changed and from that time not started or igniting more the gasoline pump, gasoline pressure regulator, the 6 coils of the spark plugs, gas filter, the two crank sensor that of crankshaft and the stick of Eleva, the internal fuse box and external enfin almost everything and the car does not start, the car will not start. thank you :(
9 years 1 month before #51089 by manual-mecanica
Manual-Mecanica response on the subject helps
I am not very sure but you have to rule out that the vehicle has mounted the electronic immobilisator that if you change the ECU and not sisters with the immine
9 years 1 month before #51109 by manual-mecanica
You have to configure the ECU When putting the computer you have the configuration of the car to which you took it by putting it in another car will not start on the dashboard will flash an icon of a key or the figure of a car inside you will see a key This indicates immobilisation when not remembered the new car
