It does not start from the key you have to push it
9 years 1 month before #51130 by manual-mecanica
They brought me to repair engine from a 1.9 diesel parnet, which was started because the engine did not have compretion. I repair the engine and cover again and the same problem had to push it to start. I blame the injected bomb that has no pressure. What opiñones there can be that going crazy .....
9 years 1 month before #51155 by manual-mecanica
Manual-mecanica response on the subject does not start with the key you have to push it
The pump must be about to correct the advance can be or very late or very avansada I would have to see and listen to the engine also depends if it smokes and what color of smoke is greetings
9 years 1 month before #51160 by manual-mecanica
Hello good afternoon. This point when you start the key non -long or smell of diesel and when you start it by pushing not long or smoke, it stops nastera and the engine is serene but when you leave it regulating for a while it seems to me. It seems to me that the pump has no pressure in low, can that be? Before making the engine they had taken the pump to fix a loss and handed it to him that he was low from compression, so I did not get out of the key, he had to push it. The owner told me that before fixing the pump the flat crawled it well but lost diesel until he stopped and I did not start more, he made the blame to the pump and I had it fixed.
9 years 1 month before #51161 by manual-mecanica
If it can happen that it does not have idraulic precion that is the palette feeder chocolate that carries the pump, the topic that you did not tell me that the idle was abnormal or that the engine stops by itself only greetings must be measured in the test bench
9 years 1 month before #51163 by manual-mecanica
Thanks Mauro. Manñana I'm going to take the bomb and take it to prompt it, and I tell you.
