Failure in Nissan B13
9 years 1 month before #51138 by manual-mecanica
Failure in Nissan B13 published by Manual-Mecanica
Good friends A query I have a Nissan B13 With a problem the vehicle has an unstable minimum is in three cylinders but if it accelerates it has a totally normal response and everything points to do the cylinder 1 but now the beautiful thing comes the car has all new cables Rotor spark plugs has good spark and there is pulse and injection when taking out the spark plug is very normal that it is burning well the car has just hired has the just rectified butt. I have already been able to review everything possible and discard problems I need a help someone who finds some similar failure please would be appreciated by any help.
9 years 1 month before #51139 by manual-mecanica
Manual-Mecanica response on the subject failure in Nissan B13
Jimmy594 wrote: Good friends A query I have a Nissan B13 with a problem the vehicle has an unstable minimum is in three cylinders but if it accelerates it has a totally normal response and everything points Rectified, well in short I think I have already been able to review everything possible and discard problems I need a help someone who finds some similar failure please would be appreciated by any help.
I clarify that the problem appears to be in the cylinder one because it is the only one that does not fail to silt fail with disconnecting high cables or the connectors of the injectors all the other cylinders if the head is noticeable when doing this
9 years 1 month before #51140 by manual-mecanica
You can check the load pump and filters, everything indicates that it is due to lack of fuel, when you accelerate more fuel pressure or
or on low it is not enough, also the line is half covered, you did not say so the system is electronic because it can be the admission sensor
9 years 1 month before #51141 by manual-mecanica
Check the coil, this trisado may have the cylinder cable 1.
or you can also check the valves taking the engine compression.
