Ayda with Jetta A4 changes
9 years 1 month before #51150 by manual-mecanica
Ayda with changes from Jetta A4 published by Manual-Mecanica
Hello, how are you, hey I have a problem with my A4 jetta:( :( in the speed changes since the first third and fifth do not enter the first to return to the previous change so that between, for example I go in second and to want to put third topa and I have:)
9 years 1 month before #51151 by manual-mecanica
Manual-Mecanica Response on the AyDA topic with Jetta A4 changes
If it is manual transmission you have to review the synchronizers
9 years 1 month before #51152 by manual-mecanica
Hello, good,
have the engine with water washed? Sometimes in certain VW when washed the engine and sneaks water into the clutch tend that the speeds do not enter well until all the water or moisture has dried. Or synchronized from the box or clutch that is not very fine.
You will tell us
a greeting
9 years 4 weeks before #51169 by manual-mecanica
Friends thanks for your comments apparently if it was because it washed it because when checking the gear, everything was good, it was only the water that dried the dry one, we put everything again and now it goes as if nothing had happened
