Help with Nissan Navara, engine does not start
8 years 11 months before #51321 by manual-mecanica
Help with Nissan Navara, Motor does not start published by Manual-Mecanica
Hello, I would like to exchange information about the ignition of a 2014 Nissan Navara, it is changed torokes, it is armed according to catalog and does not start, I made the review again of the assembly, the synchronization of the two chains is correct, but I have a doubt, the right camshaft is the one that carries the signal of the signal in the tail, where the signal Cams axis, it is in the draft groove, but does not act with the sensor, I think it is missed its position, in what I could inform myself, the APA axis sensor works together with the position of the crankshaft.
I did the sensor operating manual test while we should start and accuse several attempts to start, of course generating the pulsation bringing a workshop key, with that discarding that the sensor was bad, but still does not start.
8 years 11 months before #51366 by manual-mecanica
Manual-Mecanica response on the subject helps with Nissan Navara, engine does not start
Hello when the vehicle is gasoline it has to start the same without or with the camshaft sensor when it is diesel with Common Rail system it will not start without the two crankshaft sensors and camshaw signal
