Automatic Climateizer Peugeot 308
8 years 3 months before #52130 by manual-mecanica
Manual-Mecanica response on the automatic air conditioning theme Peugeot 308
Good morning, the same thing happened to me, at the end of so much review there were two things, the air conditioner and the host or interior fan, since at some time to function the connections were heated and stopped working. I hope it helps you.
8 years 1 month before #52242 by manual-mecanica
Hello everyone.
I also have a problem with the air conditioning system of my 308.
The compressor does not act I have checked with a polyymore and does not reach the clutch or electro magnet of the compressor pulley that makes it turn with the Araste strap.
On the other hand, cut a 308 terminal that was for scrapping and connecting the direct battery terminals the clutch proceeded correctly.
8 years 1 month before #52266 by manual-mecanica
Scan the car, the air conditioning has a diagnostic module, it is most likely that it is your outdoor temperature sensor that is failing the Peugeot have that sensor in the right rack of the front bumper on the internal part or also in the right rearview mirrors in the case of being the external temperature sensor disconnects the right rearview mirrors, and you can also check the pressure of the gas must Motor must turn in second speed in this case the system is protected if there is no good operation of the engine refrigeration system
8 years 1 month before #52267 by manual-mecanica
Also Czech the pressure sensor installed in the high pressure pipe is the thinnest, with respect to the outdoor temperature sensor, which marks you on the aboard board that exterior temperature has, if they do not match the ambient temperature that is your fault, also check the resistance of the air conditioner. Fat and another black that tie is burned too
