Ssangyung Kiron 2.0dt não sprayed os ijectors
8 years 8 months before #51695 by manual-mecanica
ThisU Com Uma Ssangyung Kiron 2.0dt Na Office in the Nave or Moment for Function, the Bicos Injectors São Novos, to Central Já Foi Posta Em Outro Carro E operated, Já was disassembled or head of motor and review as valves, já was conferred thoroughly or command of distributing. Já is fesz reviewed high pressure pump, not diagnosis of the eleventh -diagnosis, which could be found or working engine, not the moment of starting a diagnostic machine lê uma pressão of 220 bar and sovere to insist omiting not starting two 500 bars. Detail, Der Com Spray na adissão or sticky engine and Fica working at the end or spray. Or no imobilizer
