Hello, my name is Luis. I have a problem with my car and I hope you help me looking for some solution since I am desperate.
I tell you: the first of all scheme is heated with short marches, the temperature rises almost 180 ° (up to red), especially when the car is standing. When I go by highway, logically the air cool the engine, the engine cool, at first it was only that and it took it to the workshop, they changed the thermostat and the radiator valve. Kilometers made, smoke begins to leave through the expansion vessel plug. Coot a lot of pressure and expel a bit of antifreeze liquid by the plug and start coming out. I hope you can give me your opinions, or know if the same thing happened to someone.
My car is a Renault Clio 1.9 D Chipie.
Greetings and thanks in advance.
