I need help with hydraulic braking system
8 years 6 months before #51860 by manual-mecanica
I need help with hydraulic braking system published by Manual-Mecanica
Hello! My despair has led me to try to get the missing data to be able to solve how the braking hydraulic system works that I leave attached in the photo or in the lock of the end. I explain to you what I have been able to decipher, that it is a braking system that slows the drum through a motorcycle clamp, this system can be prejudent before its operation which I imagine that it should be achieved with the elements 2 or 3 that are not seen, I have thought that there could be a braking rapid and the brake liquid deposit stop of the braking before the beginning. The number 1 I think is a modified hydraulic master piston to act with a threaded piston, what disrupts me is the placement of the manometro and the modifications it has, with respect to a conventional rally or hydraulic brake handbrake. I advocate your experience if someone expert in hydraulic systems were able to shed some light of the functioning of this system, or not necessarily this but another way to get a constant braking in the drum where the traction line that is the rope is hosted, while it is released by the drag of a boat to a free flight pilot. Thank you in advance and sorry if I have not explained in the best way, if you have any doubt more data.
postimg.org/image/f5q3pyon1/981f1758/
