Camshaft Sensor Ford. Models and types Question There are a number of models or is a t
8 years 4 months before #52016 by manual-mecanica
asked; In Ford motor models the Camshaft Sensors synchronizer is unique type? What can apply to various types of Ford motors? .- Or if you can truly vary in any component or something by being different soup of Ford motor? My question is that I have an OHV 4.0 6 cyl -fad engine, and I see that there are 4 -cylsome models, which apparently use this sensor, like 8 cyl .. It could be the same Camshaft synchronizer sensor to be used in different displacement of Ford engines. ? Remembering that its use is exclusively to send "signal" according to the degree of installation. thank you.-
8 years 4 months before #52017 by manual-mecanica
For gasoline engines that sensor is to verify the advance variation
not for the game only the rpm sensor that fails or which problem do you have?
8 years 4 months before #52039 by manual-mecanica
My problem is that I fail to synchronize 4.0 OHV 6 cyl. Piston Nº 1 PMS advance 3 lines in Damper brand and arrow send to place 60 degrees starting or degrees. I do not achieve how to locate the sensor in correct position to send a sign. I need graph and the correct explanation to place seen from the above -side plane. thank you
