Error Code P0171 and P2096
7 years 3 weeks before - 7 years 3 weeks before #53188 by manual-mecanica
Error Code P0171 and P2096 published by Manual-Mecanica
Greetings, I have a problem with my Kia Spectra 2007 and these two codes that I do not give to remove them, the car does not present vibration problems, or escape from air by any multiple tuveria, I have changed the oxygen sensors, I have cleaned the Catalitians and I have cleaned the Max Flow and the car does not take off the excessive consume of gasoline and when I turn it up, it smells a lot It does, if someone could help me with this, it would be happy, the car is well the only thing that gasoline is drink, if someone considers that I should change or check something else that please tell me, I am sick with the errors and it has me crazy, the car tampo moisters or anything and when it accelerates it, it responds very well.
An expert your help.
thank you.
Latest edition: 7 years 3 weeks before for .
7 years 3 weeks before #53189 by manual-mecanica
Manual-Mecanica Response on the subject Error Code P0171 and P2096
Yeind.Reyes wrote: Greetings, I have a problem with my Kia Spectra 2007 and these two codes that I do not give to remove them, the car does not present vibration problems, or escape from air for any multiple tuveria, I have changed the oxygen sensors, I have cleaned the catalogs and I have cleaned the Max Flow and the car does not take the excessive consumed of gasoline and when I turn it up, when I turn it up. Gasoline raw, it is all that it does, if someone could help me with this it would be happy, the car is well the only thing that drinks the gasoline, if someone considers that I should change or review something something other expert that please tell me, I am sick with the errors and it has me crazy, the car tampo humans or anything and when it accelerates it responds very well.
thank you.
