It does not go from 130 km/h. AID!!!
4 years 9 months before #54124 by manual-mecanica
It does not go from 130 km/h. AID!!! Posted by manual-mecanica
Hello, I have bought a pegasus cube 650 carburement of 2001, I know that it shares engine with the F650 and maybe someone knows what my problem is.
I have been with her 2 months and I can no longer ...... I need guidance or a clue that problem, I thank you in advance.
- I have changed the oil 2 times and I have made sure to make 2 l righteous, so as not to pass with the level. In the end I have left it with a 0W30. It has already improved 5000 rpm.
- I have adjusted the carburetion according to scrupulous workshop manual, it was really bad. Adjusted mixing screw (2 laps) and mounted 107.5 high and 65 low gum.
- I have reviewed full admission and full exhaust lime in case I had mounted power limiters. All ok.
The motorcycle costs a lot to reach 120 km/h, and from 5000 rpm it is like the engine stops and loses power, in short marches it reaches 8000 rpm but in 5 ° it does not supra the 6000 rpm. Any idea?
Please help .....
