The theme is a 1.8 Evolution Corsa
16 years 7 months before #5494 by manual-mecanica
The theme is a 1.8 Evolution Corsa published by Manual-Mecanica
Greetings, the theme is a 1.8 Evolution corsa, the precion is raised, losing refrigerant, by lid, or in the union of the aluminum with the plastic tank of the radiator, the thermostat is changed, and the spin or temperature sensor, which governs the fan, the radiator is cleaned, only when the air conditioned is on this does not happen. Thanks in advance
16 years 7 months before #5499 by manual-mecanica
Manual-Mecanica Answer on the Re: The theme is a 1.8 Evolution Corsa
Hello, the tip of how this same situation passes you and you are going to afford you: Blink: just have to change the clogger of the berry or deposit of the antifreeze this is because it loses precion and no longer seals I hope you also solve the problem;);)
16 years 7 months before #5581 by manual-mecanica
Remember that Corsa have two speeds in the engine fan may be that the first is not working.-
16 years 7 months before #5615 by manual-mecanica
thanks I didn't know
16 years 7 months before #5620 by manual-mecanica
Hi Extrella, look there are several things that Saver, all vehicles that are heated when using the air conditioning works another fan that helps to cool the refrigerant, you have to keep in mind that the filling of this type of depocitos is not until the top, since if you do this, the excess will be bounced by the cover, you just have to fill it up to half Systems are purged but you have to fill them cold, if it is not passed, to check the compression of the cylinders to rule out that it is going to combustion because the packaging is blown, or the cylinder head crooked, if it boots the liquid only when you stop the car check the pump, the cover is also important because the system pressurizes the system.
