URGENT! Central closure Toyota Corolla
16 years 6 months before #6083 by manual-mecanica
URGENT! Central closure Toyota Corolla posted by Manual-Mecanica
I have a Toyota Corolla 1994. I had an installed alarm. The remote control battery was over and in despair to start the car and go to work, I got under the board and started starting some cables that I believed were of the alarm until I got the car to start. Then, I ordered the alarm to uninstall, but surprise; The central block is activated every second by exceeding 20 km/h. And it is about to leave crazy, since every second \ "closes \" the doors making the typical sound \ "tac, tac \" !!!
Apparently, when you release some cables (which I thought were alarm) were of the central block and something is not functioning as it should.
If please someone helps me, I will be very grateful !!
16 years 6 months before #6095 by manual-mecanica
Manual-Mecanica response on the re: urgent topic! Central closure Toyota Corolla
Look, the first thing would be to save what type of alarm you have, the other thing is that I do not think you have or that last to carry any centralized cable, what can happen is that your alarm activates the closure, that is to say the alarm and the closure go together, in any way it is not a problem that you can solve alone, these systems are complicated means, but any house that puts alarms can solve the problem, nothing of concessionaires or official houses. Even a good electric can help you
16 years 4 months before #7074 by manual-mecanica
I was finding out a bit and I think I know where the problem is.
The central closure has a \ "closure \" system itself that when the 20km/h passes, it is activated by blocking the doors.
The only way that this can be done is that there is a connection of the central closure switchboard with the velocimeter of the car.
The problem of my car, is that when passing the 20km/h, the closure is activated every 1 or 2 seconds until it reduces the speed below 20km/h.
Apparently, when the alarm disconnect, I have released some cable that connects the speedometer with the switchboard.
Will I be right?
16 years 4 months before #7121 by manual-mecanica
Look if you disconnected any cable from the switchboard towards the account, I do not think that there is a problem or they are open or closed but they open and close, the best Ceria connect everything again and Provar, the problem that to help you more would have to have the vehicle and test it to save well, or the other that can be is that a cable of this short acth and activate you and deactivate you, by bad contact.
16 years 4 months before #7122 by manual-mecanica
It would also be useful as many cables and color are if you can supply a better photo.
