Solex Carburetor 32-34 Z13
16 years 6 months before #6277 by manual-mecanica
Solex Carburetor 32-34 Z13 posted by Manual-Mecanica
Hello friends: First of all thank you! For telling me how to get the Renault starter engine. Could it be that the chicler of low cover has?, Or what else can it be? The carburetor is a Solex 32-34 Z 13, with a staggered double body. Thank you!
P/D: My email is
16 years 6 months before #6294 by manual-mecanica
Manual-Mecanica Answer on the Re: Solex Carburetor 32-34 Z13
First you will have to disassemble the carburetor to be able to disarm it and see what happens or can try an carburetor if it improves, you take it out and clean it if it does not improve the fault can be electric and not fuel, Tieme chicler electronic that model right?
16 years 6 months before #6311 by manual-mecanica
The best thing you can do with the carburetor, is to ask for the carburetor repair game \ "Solex If-32-34 Z13 \" in a car spare parts.
This repair game consists of:
-Juntas,
-Clekening pump membrane,
-Aguja,
-Needle -cake
-tapones and filter mesh (in some models)
Next, with patience, you dismant gasoline tubes and finally the screws that hold it to the
admission
collector carburetor outside the car, we will proceed to disassemble it patiently and with the precaution of not losing any piece, and taking the precaution of placing the separated chiclés so as not to mix them (in the case of the double body)
. Liters cut by one side, solvent and a brush, we are cleaning it until it is left as a new eye that the solvent places and drills !! that apart from being
flammable
. It will proceed to the start of the engine (it can cost a little because the tank is empty of
gasoline
Lowering the slowdown we will act
on the butterfly screw, tightening to climb turns and loosening to lower it
16 years 6 months before #6413 by manual-mecanica
Hello, I would need if the Renault 9 carburetor exploded manual is possible, I explain why it is accelerated and I think that springs are missing, but no idea where they go, for that reason if anyone knows or has it, thanks
