- Thanks received: 1
06-19-2025 Hits: 862 Technology
It looks a lot that they are air intakes due to deterioration of the joints. The fact is that mine does not drip anything, but I am still going to take it out and look at it, because I am in a little time with the doubt of whether they will only be the joints or in the end I will have to change the whole pump.Camelio1 wrote: Hello everyone, I see that you have a lot of experience in the subject and I wanted to present my case.
I have an omega 2.5TD of 95 has not given me problems so far. The motor failure light is turned on when lifting a accelerator's foot, for example I give an accelerated and loose and it is already turned on, when you release accelerator to change your gear too, sometimes I stop, even on the road when I am going to change when I lift my foot. If I drop it on the road. It remains as force. When I start all the mornings everything well but when the ground is lowering, when the engine is taking temperature, it starts to head and removes a while when the car takes temperature 90º. Regarding the body of the pump? Do you think I have air intake problems and a primary gas pump failure? The side corner screw of the regulator I think it can be removed with a key in inches fitting it, you can tell me that dimensions ..... Thank you very much
more data is the same pump that mounts the BMW 525TDS from 02/95.
It is the Bosch VE6/10E2400R515 (0460406994)
