I need Motor Ford Escort Help 1.8 Diesel Pump
16 years 5 months before #6676 by manual-mecanica
I need help engine ford escort 1.8 diesel pump published by manual-mecanica
Hello everyone, I need help :(, I have a Ford Escort 1.8 diesel. When I take off the contact key,: UNSURE: after asking what is said that it is due to the even electrovalve that is in the injection pump, someone could help me indicating how I got to the electrovalve
16 years 5 months before #6683 by manual-mecanica
Hello,
the pump's electro is normally in the superio part in how a oil pressure temperature bulb and has connected a single luck cable
16 years 5 months before #6696 by manual-mecanica
[IMG SIZE = 150] [/IMG] [IMG SIZE = 150] [/IMG] [IMG SIZE = 150] [/IMG] THANKS NESTORNT, for your clarification. I see what you know what you are talking about, t specifying that it has at a sight, I imagine that it is the Carasa d steel qt taught in the photo, so I would dare to ask you a last question, how do you take this housing, can it be with this screw?
16 years 5 months before - 16 years 5 months before #6697 by manual-mecanica
Latest edition: 16 years 5 months before by .
16 years 5 months before #6719 by manual-mecanica
Before making any cora, check the ground cable from the battery to the engine and the body auxiliary to the body, possibly do not make a good contact yhaga return of mass by the pump.-
