AIR CONDITIONED SEAT CORDOBA TDI 1998
16 years 5 months before #6787 by manual-mecanica
Manual-Mecanica Response on the Re: Air conditioning Seat Cordoba TDI 1998
I forgot I think that in that model the evaporator does not wear temperature sensor because the compressor is of variable compression carries a valve in the valve plate of the compressor that affirms that function
16 years 5 months before #6804 by manual-mecanica
All systems carry a brine or thermostatic sensor in the condenser or anti-freezing, or if you do not know how to deactivate the compressor apart from reading the pressures.
16 years 5 months before #6805 by manual-mecanica
apart what is the brand of the compressor that the car has installed to see what type of system uses
