Toyota Duet 2000 ignition problem
16 years 5 months before #6801 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with the ignition Toyota Duet 2000
Hello, remember something that if the pressure is low also makes you as if it drown but in reality it is not enough fuel, the air filter like this
16 years 5 months before #6802 by manual-mecanica
Also check if you are released some air vacuum hose that go from the admission collector to some senses, it can also be the EGR valve that has been blocked and you are creating that fault.
16 years 5 months before #6814 by manual-mecanica
Saves because of the color of the spark plugs you mention you have very little air in the mixture and a lot Ronpio and that is why he doesn't part, all that tells you the Scanner.
It is better in the long run, since you will not change pieces to change.
